Posted January 5, 201115 yr Whats up... I planned on having a box built for my BL back around june but just went with a prefab box at my local shop which was a BAD idea. Cant stand how it sounds honestly and finally would like to switch it out for something tuned lower and slightly bigger. Car is an 08 scion tc, the trunk is extremely small so these measures are the absolute max for a box (including carpet/baffle etc..)Height= 17.25Depth (front to back)= 16.65Width (across)= 31.80Its a hatch trunk and it curves around the corner so thats the biggest size box that can fit I believe. Considered doing Sub up port facing the rear to have a bigger box but I think i will play it safe and continue to have sub/port facing the rear. Heres the current setup so you can get a bit of an idea. http://img412.imageshack.us/img412/4069/img2746vl.jpg Ported to 34Hz. Black or Dark Grey Carpet. Double Baffle, and flush mount maybe? (not sure what it is) But this box will be home for a BTL 15" later this year so whatever you think would be good to add. I'm around Boston, so let me know if this can be done and a rough estimate of the price, and if it can be shipped to me before next weekend, if not its completely fine, no rush. Thanks - Mike
January 6, 201115 yr With the dimensions you gave there is not enough room to make a proper size ported enclosure. I was using the min air space Fi recommends which is 3 cubes. Andrew
March 16, 201114 yr Hello,Sorry the the delay in the response, we have moved locations and restructured a bit.Are you still interested in an enclosure?Andrew
