I currently have a 90 amp alternator, im not sure if i should purchase a HO alternator (150 amps).
During the week i will be doing the big 3 upgrade along with purchasing a new baterry.
The battery im getting is a Deka Intimidator AGM battery:
Group Size 78
Warranty 72 Month
Chemistry AGM
Cold Cranking Amps 740
Cranking Amps 850
Reserve Capacity 120
Amp Hour Rate 55
The sound system im going to be adding is 2 12 Fi BLs and a hifonoics Brutus BRZ2100.1D.
So, do i stay stock or go to HO alt, moneys tight so id only get the new alt if its absolutely necessary.
wait on the h/o!
just install it and keep an eye on your voltage and be conservative! also get a voltmeter!
You'd have to keep gains down in order to keep alternator from overworking itself... With 2 BLs I think you'll be fine pinching your gain to almost nil... Right???
With the voltmeter, what should i be looking for to tell if its doing good or bad
well if your battery voltage falls below 12volts turn the volume down but shogen does bring up a good point your amp will be pulling a lot so to prolong the life on the alt dail the gain down some! like if your amp is rated for 1krms run it at 800~
1000rms at 12volts = what 85amps?
and your alt makes 90amps at what idle or 3k rpm?
I believe its something like 90 at 3k rpm and 75 at idle
well you have your answer! get a h/o if you want to run more power but until you get one keep the gain down a bit and watch your voltage!
to watch my voltage i use a stinger meter!
Your stock alt does not make enough power. Put a dmm on your battery terminals with the car running, what's the voltage at idle with your lights and ac on?
Your saying 90max and 75idle, after your cars electrical stuff pulls it's amps (lights, ac, ecu, etc) your alt is barely gonna have enough for anything, much less a 2kw amp
Adding a Battery is going to help but the battery is constantly going to be discharging and your alts gonna be working 24/7 trying to keep it charged. Notice I said trying...
Not sure if deco or anyone else makes some cheap decent alts that a little upgrade from stock, but DC Power has a lower line, I think sp series? I'd defientely look into that.
Sorry if my text is misspelled, iPad... :P
