Posted January 14, 201114 yr im looking for a 270 amp alt and i sent a email to dc power i have a 2002-2.7L dodge intrepid i asked the guy he said they jeep wrangler ones will fit on my car he send me a link but the link took me to all the alts page and not the one i need so what year and motor is that one that will work with my car
January 14, 201114 yr One for the same year would be fine.. Because your PCM really wont drive an XP to it's full potential, you really should run our PCM bypass/internal regulator kit on your car.. You can *not* run it and be fine, but it just wont drive it as hard as the new Chrysler PCMs will.. It will still do good, but they are set to a pretty low voltage, and most people aren't happy with 13.8v, even with 180 amps at idle behind it. They assume that low voltage = low output.. If you have any other questions though, feel free to ask.. Thanks again, Rob
January 14, 201114 yr Author would the 180 amp you offer be ok for a sundown 3000 amp and some deka intimidator batteries
January 16, 201114 yr Author ok ive decided to save up and buy the 270 amp ill probaly be ordering it in 2 weeks so can you show me a pic of what the pcm thing you sell looks like
January 19, 201114 yr Author does the engine have to match for it to work cause mines 2.7 and the jeep is 4.0 does that matter
January 19, 201114 yr does the engine have to match for it to work cause mines 2.7 and the jeep is 4.0 does that matterAs long as the mounting brackets line up & both engine use similar belt routing I don't see why not. If you have a picture of your engine/alternator it would help.
January 20, 201114 yr I'm not 100% sure, but I'm gonna say it should. The alternator in the Jeep 4.0 engine is mounted at the top of the other side, but it looks as if the mounting brackets line up. As long as they accept returns I'd atleast give it a try. Edited January 20, 201114 yr by 00WJGC
January 20, 201114 yr so will it workYes, in your engine it will. Its not an easy install, but the jeep mounting and that mounting are identical. They are just rotated 180º the way they mount.. We've done a few of these though, so I am 1000% certain that this does work on that engine. If you have any other questions though, please dont be afraid to ask... Rob
January 20, 201114 yr so will it workYes, in your engine it will. Its not an easy install, but the jeep mounting and that mounting are identical. They are just rotated 180º the way they mount.. We've done a few of these though, so I am 1000% certain that this does work on that engine. If you have any other questions though, please dont be afraid to ask... RobThat's why I was hesitant to tell him it would work. lol...the bracket on the alternator he posted is identical to the mounting on my Jeep's, but it's kinda hard to compare when one's upside down. =]
January 20, 201114 yr Author i have a volt meter and it says like 14.3 volts and it will go to 14.4 if im driving fast then it falls down so wont this new alt keep the volts around 14
January 21, 201114 yr i have a volt meter and it says like 14.3 volts and it will go to 14.4 if im driving fast then it falls down so wont this new alt keep the volts around 14It should sit around 15v, depending on load, engine rpm, hot vs cold weather.My 270xp sits at 15.xxV and with a saz1500d at full tilt at IDLE, say 14.xxVYou'll be happy,
January 21, 201114 yr Author yea but dont i have to bybass the computer to get it that high how do i do this yes i cant wait im ordering my alt next weekend and then my system will be running againidk why but my cd player was skipping idk if it was cause of the bass vibrating it or the volts were dropping too low and the amps cut out for a secound the headunit is secrured Edited January 21, 201114 yr by markak134
January 28, 201114 yr Author so if i order my alt tomorrow when does it ship do you have them already made or do you have to build them
