  • Replies 66
  • Views 7k
  • manrossdamn
    manrossdamn
    Wood thickness is by far one of the most important things when creating a system. Like they said up there, the thicker the more durable, the less flex you have. Also, bracing is a must!
  • A solid built enclosure IS a good one. "Loud" is what you make it. Why do SQ guys have 600 watt front stages, then don't go over 90 dB? "Overhead" isn't THAT much. Having an extra thick box solves
  • Any panel resonance ("flex") at all defeats SPL. You can never predict nor really control the phase differences between the panel and system. All flex is bad.
A pretty big part id say. The thicker the wood, the less flexibility, more durability, and heavier. Thinner wood, may flex, lighter, and less durable. You don't want 1/4 panels flexing while the subs plays haha. Most people stick with 3/4 inch.
I'm guessing this is your daily driver, not for strict competition? Believe it or not but some panel flex is used for gaining additional tenths on the meter :P
Anyhow as Skizzy said, 3/4" mdf is the usual, safe bet. Double baffle (two sheets of 3/4" glued together) the panel that the drivers mount to, and internal bracing ftw :)
1/8'' bead board works well.
:peepwall:
Edited by 00WJGC
:peepwall:
Mine as well use particle board :attempt:
All flex is bad.
I've seen people have a little flex in there boxes and lost when they fixed it, tried a few different ways, all inresult was lost in SPL.
So never say never.
But in 99% of the install flex is bad. Minimal is 5/8ths, and this would be for small boxes with lightweight subs.
But 3/4ths is minimal in most cases, so start with that.
How big of part does wood thickness play in a good enclosure?
Not only does wood thickness play a part, wood type does too. Most MDF found now is a low grade, very soft MDF that SUCKS. You can tell by if it's dark or light. Dark stuff = bad. I built a few boxes, identical, out of light and dark MDF and the dark MDF was always 1.2-1.5 dB quieter. The best wood to use that is reasonably priced.... a decent grade plywood. All my 7/8" plywood boxes = louder than 3/4" plywood = much louder than 3/4" MDF. This is with a 1 cu. ft. single 8" box BTW.
Wait! No one here uses steel enclosures??? Why the F did I let that guy talk me into that $240 enclosure from steel that is on order???
:roflmao:
Also, bracing is a must! :morepower1:
Once you do a 100% steel box, you'll go back to wood. Having to tap holes and bolting in the sub is a PITA. Ask me how I know. Now if you're talking all steel except where the speaker mounts, I can show you an Explorer done that way. It's 1/2" steel.
Like already stated 3/4" is most common. You don't really need to get into double baffles unless you're working with heavy woofers(like 50-60lb+) that might be able to strip coarse thread screws in the right situation, or if you're doing a baffle with a large surface area and using some beefy subs. Properly braced single layered baffles can go a long way with a daily setup. SPL competition is obviously a different story.
I'd double baffle a lightweight 8" driver, but if you don't mind coloration go ahead and ignore dead box building techniques and use some thin shit.
What exactly are you gaining by doubling up on a little 8"er? You might as well just brace a single layer to get the box resonance out of the sub's passband.
Edited by RAM_Designs
Frequency is not the only portion of the resonance you should address, in fact I'd be more concerned about damping and altering the Q than where it is. Personally I wouldn't ignore either.
I'd really like to see this enclosure ...
oh sry Cable.. that isn't possible...
Reason being that it was a joke... lulz...
Because then you deal with the complications of internal bracing? Yes, there are adverse affects. I NEVER use internal bracing.
Why?
I'm sure bracing in an acoustic suspension enclosure, a 4th order, or a 4th order bandpass wouldn't hurt.
:lol2:
Why?
:lol2:
Wherever there is air flow, it causes problems. Perfect example (and not the only case), in my S10 I did no internal bracing and made the box 5.25" thick except for the baffle which was 6" thick. If you put ANYTHING in that box, score dropped. I left a drill in the box once and lost over 1 dB. In other smaller box applications, I've heard turbulence from bracing as well. Depending how your brace is, I could see it causing a problem with phase or standing waves. The only bracing I'd deem usable is thick threaded rod.
Why?
:lol2:
Don't assume everyone is concerned about a "score". Acoustic reproduction might just hit the list as important...
It also depends on how your internal bracing is structured. Some may actually help with flow.
