Posted January 19, 201115 yr i need to know which sets to get.. im going to be running 8 10s in my car and i need to get down to a 1 ohm load.do i need 8 single 8 ohm subs or 8 single 4 ohm subs i was leaning torwards the 8 ohm singlesbut need some help
January 19, 201115 yr Depends on the amplifier, for a final 1 ohm load you would need 4 ohm coils, and for a final load of 2 ohms you would need the 8 ohm coils
January 19, 201115 yr Depends on the amplifier, for a final 1 ohm load you would need 4 ohm coils, and for a final load of 2 ohms you would need the 8 ohm coilsDid you actually read the original post at all? If he was doing DVC's he'd need 4 ohm coils and wire it series parallel.If you want 1 ohm with 8 SVC subs, you need 8 ohm coils.
