January 22, 201115 yr I also saw a product where they are selling a 2 awg wire that you hook up to your alternator (the bolt with a wire attached to it) directly to your battery (or the positive on your fusebox, where you would put the positive jumper cable) , instead of just the skinny stock wire dissappering into your engine somewhere and eventually going to your battery. I did it , it helps. http://www.zzperformance.com/grand_prix/products1.php?id=178&catid=108
January 22, 201115 yr I also saw a product where they are selling a 2 awg wire that you hook up to your alternator (the bolt with a wire attached to it) directly to your battery (or the positive on your fusebox, where you would put the positive jumper cable) , instead of just the skinny stock wire dissappering into your engine somewhere and eventually going to your battery. I did it , it helps. http://www.zzperformance.com/grand_prix/products1.php?id=178&catid=108Thats one part of the Big 3, which OP should do if they haven't already. I suggest getting 1/0 at least to do it though, with this kind of upgrades/power plans.
January 22, 201115 yr I also saw a product where they are selling a 2 awg wire that you hook up to your alternator (the bolt with a wire attached to it) directly to your battery (or the positive on your fusebox, where you would put the positive jumper cable) , instead of just the skinny stock wire dissappering into your engine somewhere and eventually going to your battery. I did it , it helps. http://www.zzperform...d=178&catid=108The wire you refer to is part of the big3. The other two wires are a ground wire from the alternator to the battery and a large ground from the battery to the frame/body of the car.
