Posted January 22, 201114 yr hey guys....new here and i just bought a pair of NIB SA-12s from a member on here as well as a MB Quart DSC1500.1......i am about to start building a box in the next few days and using the box calculator this is what i come up with.....seems to fit the parameters of the subs well and from what i have been reading i think i am pretty close.....just wanted some opinions and some input from some of you guys first before i go ahead with it....the dimensions below are kinda all i have to work with....i have a 2009 Jeep wrangler unlimited and wanna stay in the back under a cover.....basically i have 36x15x22......i wanna do a slot ported box.....thanks Edited January 22, 201114 yr by ghost28
January 22, 201114 yr Looks to be alright. I'd round-over those port corners if you plan on pushing those subs pretty good, just to be safe. Don't forget about bracing either.
January 23, 201114 yr If its a slot port the numbers are wrong. It will be more like 3.9ft^3 @ 32hzYeah, I'm trying to figure out how it's getting that much volume for the port. I'm getting around .75ft^3...it's kinda hard to follow something like this without a picture because you're not sure of how everything is laid out.
January 23, 201114 yr Author RAM......How much for you to do a design and set of plans??? I didnt even know there was someone like you on here..... I am gonna double check my available space and probably go that route....I know i could do it without but i would love to have a set of plans to make my life easier.....i have ALL of the tools and know how to use them so i think this would be perfect.....
January 24, 201114 yr RAM......How much for you to do a design and set of plans??? I didnt even know there was someone like you on here..... I am gonna double check my available space and probably go that route....I know i could do it without but i would love to have a set of plans to make my life easier.....i have ALL of the tools and know how to use them so i think this would be perfect.....Good deal, look forward to hearing from you.
