Posted January 24, 201114 yr can you starp 3 audioque 2200d amps togeather to 2 12inch fi btl 12s fully loaded and if so what ohm load would if have to drop to
January 24, 201114 yr You cannot strap 3 amps together. Only 2, master and slave. First off what are the coils on the subs? Do you have them already or is this still in the planning stage?My first suggestion would be to slow down and asses your goals for the system and what your wiilling to do to achieve them. Takes ALOT to support a 4K+ system. And if you have to ask questions like this, then you are probably not ready for one. Not bein a dick, just bein real.
January 24, 201114 yr Author I just have 3 amps I just wanted to know if I could use them Im undecided but I want to go with 2 12s xcon an 1 amp to each but I don't know if that's to much power for each sub I know I can set the gains low but is that a waist am I better going with 2 fi btls
January 24, 201114 yr Again this would depend on your goals. The Xcon is a SQ based driver that can get really loud and sound good doing it.The BTL is a SPL based driver that happens to work well in daily setups and sound good at the same time.Either one should be able to take an AQ2200 each in the proper enclosre and gains set correctly (clean signal). And don't forget the electrical to back the amps, atleast an HO Alt and a few group31 batts.
January 24, 201114 yr I'd sell one amp and just be happy with 2k to each sub. Edited January 24, 201114 yr by RAM_Designs
January 24, 201114 yr Yeah, forgot about that. SO what ohm load would you shoot for. WHat would you strap at?
January 24, 201114 yr Use for strapping 3 ampsPretty stupid you don't even explain why.I'll do it for you. Reading > me. the site I went to ( http://www.maxxsonics.com/corporate/news_0107_Hif_MAXXLINK.html ) said nothing about having to use pairs of amps so I assumed you could use an odd number, but apparently you must use pairs of amps with it. http://www.hifonics.com/Hifonics_Maxxlink.html
January 24, 201114 yr Use for strapping 3 ampsPretty stupid you don't even explain why.I'll do it for you. Reading > me. the site I went to ( http://www.maxxsonics.com/corporate/news_0107_Hif_MAXXLINK.html ) said nothing about having to use pairs of amps so I assumed you could use an odd number, but apparently you must use pairs of amps with it. http://www.hifonics.com/Hifonics_Maxxlink.htmlYou got me wrong. I was face palming myself cause I thought I was wrong and you could strap 3 amps with the MaxxLink. That should explain my other post as well. lol
January 24, 201114 yr Use for strapping 3 ampsPretty stupid you don't even explain why.I'll do it for you. Reading > me. the site I went to ( http://www.maxxsonic...f_MAXXLINK.html ) said nothing about having to use pairs of amps so I assumed you could use an odd number, but apparently you must use pairs of amps with it. http://www.hifonics....s_Maxxlink.htmlYou got me wrong. I was face palming myself cause I thought I was wrong and you could strap 3 amps with the MaxxLink. That should explain my other post as well. lolLOL, well we got to the bottom of it at least.
January 26, 201114 yr Yeah, forgot about that. SO what ohm load would you shoot for. WHat would you strap at?What's the VC configuration of your subs?
