Posted January 24, 201115 yr Hey I am planning on getting a 12' btl and with spending the least amount of money what kinda amp, alternator, battery etc? Should I get
January 24, 201115 yr Lol, btl probably shouldn't be an option if you don't have the budget for a big amp, extra batts, alt. But if you're set on it, an AQ 2200 or Audiopipe 3000 are decent budget amps. Get the biggest battery you can fit under the hood and a group 31 in the back. A decent battery at a great price are the Deka Intimidators. Depends on your stock alt, but you will probably need a HO alt for 2k+. An alt is something not to go cheap on. Contact DC power to get a quote on one of their alts and tell them how much power you'll be running.Remember to plan for 1/0 gauge copper wire. The most budget friendly 100% copper wire is welding cable found here Do the big 3 in 1/0 gauge also.Plan for more money on fuse holders, fuses, ring terminals, crimper/solder and torch, cable cutters, etc.
