Posted January 30, 201114 yr i have a dodge charger. this will be my first system and i was wondering which to get if i had a hifonics 1200w amp and i am doing a band pass box. which do you think would be best for spl
January 30, 201114 yr First system and you're going bandpass? Where you getting this box from or are you building it?
January 30, 201114 yr Author audio innovations i heard he is the only guy in the world that knows how to do it perfectly
January 30, 201114 yr Author also idk if its just me but it wont let me look at the ssd i want to know the specs and price
January 30, 201114 yr im sure there is a few more out there in the world lol. ssd is being upgraded to a new style i think ,should be available soon Edited January 30, 201114 yr by smashedz28
January 30, 201114 yr First system and you're going bandpass? Where you getting this box from or are you building it?x2, go ported.
January 30, 201114 yr I'd go ported as well, for first system... I usually went sealed but I have my first real ported enclosure in the works...
January 30, 201114 yr there is alot more to it than just picking out subs for you, give these guys all the info they need so you get the proper help
January 30, 201114 yr Cubic feet in your trunk??? Do you have enough room? AFAIK, 1 12in SSD or BL would require 2.5 cubes, not including the port... So you need double that. Does your charger have the room?
January 30, 201114 yr I'm going to assume you have everything else planned out already . The two 12's will have more cone area than the one 15 in say a 4 cubic box so if you are throwing 1000rms at them the 12's will move more air.
