Posted January 31, 201114 yr Hey guys,so my girlfriends brother has a trans am and is trying to find a sub to go in it. the problem is he doesn't want to lose the t-top space in the back which means no box for a sub. In his car there is a board that seals off the hole where the sub is sitting. When the trunk is shut, it's sealed off.Anyways my question is what's a good sub to use for a set up like this? (10in under $200) (not his trunk, just pic for reference)Thank you. Edited January 31, 201114 yr by DanK
January 31, 201114 yr i used to have a few camaro's with this back hatch area like this. option 1. forget about the t-top holders and just build a wedge style box to fit in there (like the picture). option 2. I believe its Q Logic who sells a custom sealed enclosure for those cars, it hides in the back side allowing you access to the t-top holders. nothing special at all but its an option. If he is semi-serious about his system then he should go with option 1. those camaro's/trans-ams always sounded good for me with the sound bouncin off that back window.
January 31, 201114 yr I think i was wrong about that q logic idea, cant seem to find it. I know if you get the bose system in those there is a 8".. maybe 10" sub in the rear. might be able to build something into that area.
January 31, 201114 yr Unfortunately, you can not get a proper seal, nor do you have the proper area in there for and IB application.
January 31, 201114 yr found that Here never used this company at all, just showing you the box i was talking about.here's another that seems to have done both.
January 31, 201114 yr Author smashedz28 thank you for such a quick reply.I'll show him the options and see what he thinks.Personally i would go with the last option.So the IB option is out of the question?I mean he has sum old sub in there right now and it doesn't sound too bad, of course it cannot be compared to a boxed sub.
February 1, 201114 yr You might be able to fit a box on the rear shelf placed up to the back seat for a single or dual 8. IIRC I saw a build like that somewhere.
