Posted February 11, 201114 yr Tomarrow I will build a new box for my new Xcon 12. I have two designs to pick from, one will be 2 cubes at 30hz and other will be 2.4 cubes at 30hz depending how much room I want to give up. (or anywhere in between I suppose)When I first got the Xcon, I put it in the box my Death Row was in. About 2.1 cubes at 31 hz, with 25^2 inches of port. There was definately some chuffing going on. My new box I want more port area. Max height of port will be 12.5 inches (14inch max height for box). Will either do 2.5 or 2.75 inch wide, for 31.25^2 in or 34.38^2in. Will either of these help with the port chuff I experienced with my old box? I know the bigger the better usually, and I can certainly fit the larger port. I will round over inner port entrance and also the exit. Can't do any kerfs though. Just looking for some final input before the dust flies tomarrow morning
February 15, 201114 yr Admin Bigger to a point. Lance makes a great post above. If you can get 33^2" and up, you should be good to go. The 2.4 cubes at 30ish hz would be sweet.
