February 13, 201313 yr just make sure if you order just get the bags even if they're a bit messy.... no sense spending all that extra on the jug non-sense.... unless you buy it one time and then re-use it for the next order... that's what I plan to doThe jugs are only like $0.75 more, and you don't have to deal with a possible mess? they charge .75 per lb which can get annoying if you order like 15-20 lbs of stuff.... or high dollar proteins..... just my opinion.... I mean I ain't cheap but shyt it's extra monies....lol
February 14, 201313 yr Author just make sure if you order just get the bags even if they're a bit messy.... no sense spending all that extra on the jug non-sense.... unless you buy it one time and then re-use it for the next order... that's what I plan to doThe jugs are only like $0.75 more, and you don't have to deal with a possible mess? they charge .75 per lb which can get annoying if you order like 15-20 lbs of stuff.... or high dollar proteins..... just my opinion.... I mean I ain't cheap but shyt it's extra monies....lol I did get an answer on that BTW. It is due to the cost of the jug. When you buy a 5 lb order (most you can get into the biggest jug) the .75 per jug is just eaten up. When you buy 3 lbs (smallest in that jug size) they lost money per jug. J
February 14, 201313 yr Author Guys lemme talk to them about the jug thing if it hasn't been changed by now.I TRULY thank you all for your orders!!!!JI have to order a jug for the protein every time. I tried to do the food grade bag and pour into an empty jug, but the amount lost and the mess made and the hassle is not worth it. Aaron, What about moving the protein into the top and cut off the bottom corner? Make like a funnel with the bag. Should pour right in with no spill. J
February 14, 201313 yr Admin Guys lemme talk to them about the jug thing if it hasn't been changed by now.I TRULY thank you all for your orders!!!!JI have to order a jug for the protein every time. I tried to do the food grade bag and pour into an empty jug, but the amount lost and the mess made and the hassle is not worth it. Aaron, What about moving the protein into the top and cut off the bottom corner? Make like a funnel with the bag. Should pour right in with no spill. JTried that. The gemmo protein is very clumpy and does not flow out easy, then just sticks to everything it has floated down upon.
February 21, 201313 yr Author Guys lemme talk to them about the jug thing if it hasn't been changed by now.I TRULY thank you all for your orders!!!!JI have to order a jug for the protein every time. I tried to do the food grade bag and pour into an empty jug, but the amount lost and the mess made and the hassle is not worth it. Aaron, What about moving the protein into the top and cut off the bottom corner? Make like a funnel with the bag. Should pour right in with no spill. JTried that. The gemmo protein is very clumpy and does not flow out easy, then just sticks to everything it has floated down upon. Well shit. Maybe just set the opened bag inside an open jug? J
February 21, 201313 yr Guys lemme talk to them about the jug thing if it hasn't been changed by now.I TRULY thank you all for your orders!!!!JI have to order a jug for the protein every time. I tried to do the food grade bag and pour into an empty jug, but the amount lost and the mess made and the hassle is not worth it.Aaron,What about moving the protein into the top and cut off the bottom corner? Make like a funnel with the bag. Should pour right in with no spill.JTried that. The gemmo protein is very clumpy and does not flow out easy, then just sticks to everything it has floated down upon. Well shit.Maybe just set the opened bag inside an open jug?JI have done that.
May 10, 201313 yr Admin Next order in, making it 6 orders total and $796 spent since 12/2011 with them.
May 14, 201313 yr Once I finish off this tub of Dymatize I'll probably grab a 10 lb. bag of soy from TN. Still think the $10.45 shipping for a single pound versus $17.31 for ten pounds of powder is silly as hell though.
May 15, 201313 yr Author Once I finish off this tub of Dymatize I'll probably grab a 10 lb. bag of soy from TN. Still think the $10.45 shipping for a single pound versus $17.31 for ten pounds of powder is silly as hell though.I can respect that man. We appreciate the continued business.J
May 24, 201313 yr 10 lbs., heavy on the flavoring, en route. Plus some scoops because I somehow lost mine.
June 17, 201313 yr Shipping costs to my area are down to 9.50 per single pound and 15.74 per 10 pounds. Keep up the good work, guys. Might be ordering some NO Holds N-O in the near future.
June 18, 201313 yr Author Glad to see shipping going down for you, and that you are still satisfied. Thanks again!!!J
June 21, 201313 yr Admin Side note, I tried some of ANT's oatmeal. It is actually quite good, especially since I could blend it like Truenutritions protein.
June 26, 201313 yr Shipping costs to my area are down to 9.50 per single pound and 15.74 per 10 pounds. Keep up the good work, guys. Might be ordering some NO Holds N-O in the near future. Silly question, does the NO Holds come with its own scoop? There's no clear indication that it does. I'm assuming it does, but you know what happens when you assume.
June 26, 201313 yr Author To my knowldge everything besides pills, and liquids should have it's own scoop.J
June 26, 201313 yr Author Side note, I tried some of ANT's oatmeal. It is actually quite good, especially since I could blend it like Truenutritions protein.Hows the flavor and pricing? Nutritional content?Still unsure of him and nutrition being in the same sentance.J
June 27, 201313 yr Admin Side note, I tried some of ANT's oatmeal. It is actually quite good, especially since I could blend it like Truenutritions protein.Hows the flavor and pricing? Nutritional content?Still unsure of him and nutrition being in the same sentance.JWith the coupon code, it was $30 for 4lbs which eating it every morning, and my son having some, it has lasted 2 weeks. Nutritional content is good, I was able to mix in flax seed and dried strawberries. I was going to make one more order today and see if I want to stick with it, along with another TN protein order as I have now added a shake in the morning so I will deplete my supply even faster.
August 8, 201313 yr Maybe I should jump on the bandwagon.I usually order from BB.com. since there are some big fitness guys in here with good reviews, ill give it a shot.Any flavor suggestions? Probably just a protein for now. I'm about out.
August 8, 201313 yr Admin Maybe I should jump on the bandwagon.I usually order from BB.com. since there are some big fitness guys in here with good reviews, ill give it a shot.Any flavor suggestions? Probably just a protein for now. I'm about out.I don't worry too much about flavor as I drink it too fast, but the natural flavors are usually fine. I always get the vegan-gemma pea protein. Very high absorption rate, affordable and mixes fairly well. Only thing is that it is very fine powder that is clumpy and can get everywhere if you don't order it with the jug/scoop.
