Posted February 19, 201115 yr Does someone have all the specs to the old SSD's? I want to have them just for references because Fi took them down off of their website. Thanks is advance.
February 19, 201115 yr Does someone have all the specs to the old SSD's? I want to have them just for references because Fi took them down off of their website. Thanks is advance.which specs do you need exactly. i dont know all of them.800 rmsdual 1 or dual 2 ohmweight is around 23 pounds i think
February 19, 201115 yr Author I pretty much just want all the specs that the other subs have on their website.
February 19, 201115 yr Author specs like this(these are for the BTL N2)Fs: 39.6 Hz | 39.2 HzRe: 0.7 Ohms/coil | 1.4 Ohms/coilQms: 6.40 | 6.47Qes: .25 | .25Qts: .24 | .24Mms: 225g | 231gSd: 480cm^2 | 480cm^2Vas: 23.1 l | 23.1 lSpl: 89.5dB1W/1m | 89.4dB1W/1mBl: 17.8 N/A | 25.1 N/AXmax: 28mm * | 28mm *Rms: 2000W * | 2000W *Sealed box: N/A cuft | N/A cuftPorted box: 1.7-2.5cuft | 1.7-2.5cuftSub OD: 12.500” | 12.500”Cut ID: 11.125” | 11.125”Mounting depth: 8.125” | 8.125”Displacement: 0.12cuft | 0.12cuft
February 21, 201115 yr go to smd and check out the fi section there. they have a sticky of the older fi sub specs.
February 23, 201115 yr Author go to smd and check out the fi section there. they have a sticky of the older fi sub specs. Found it man, thanks. Here's the link if anyone else is interestedhttp://www.*****.com/board/topic/5664-official-fi-subwoofer-specifications-pictures-included/
