Posted February 27, 201115 yr Well, I'm pretty much excited right now. Just ordered my new BTL N2 18 a few minutes ago. Just wondering if you guys think an aq2200 will do the trick of supplying this beast with the power it needs, and if not, feel free to give me an affordable suggestion.Also, do you guys think a high output alternator would be necessary for a late 90s Tahoe if I wired another battery in the trunk?
February 28, 201115 yr Well, I'm pretty much excited right now. Just ordered my new BTL N2 18 a few minutes ago. Just wondering if you guys think an aq2200 will do the trick of supplying this beast with the power it needs, and if not, feel free to give me an affordable suggestion.Also, do you guys think a high output alternator would be necessary for a late 90s Tahoe if I wired another battery in the trunk?Depends on your listening habits Are you going to be playing at full tilt 99% of the time? Or just for short demos?What battery were you looking at for the rear? I'd get the biggest xs power or kinetik you could afford, watch your voltage at full tilt, if it's consistently low, get a h/o alt.
February 28, 201115 yr I'd go with an alternator. I have a h.o and 1/0 big three done, and I'm going to be getting a second battery too.That Audioque can suck some power, and if you're like me, it's loud almost all the time.Also, you know you just doomed yourself to posting pictures of this beauty when you get it? haha
February 28, 201115 yr That AQ 2200d should be a great match with the N2. I'd upgrade the big 3 with 1/0, replace the starting battery with a 100ah or bigger and add the biggest battery you can afford in the back, preferably a 100ah+ should do it, nobody really knows for sure though.
February 28, 201115 yr that AQ will power that btl just fine. I use a sundown 1500d on mine and it sounds great. H/O alt inst a bad idea. if it fits in the budget i would do it.
March 2, 201115 yr Author Well, I'm pretty much excited right now. Just ordered my new BTL N2 18 a few minutes ago. Just wondering if you guys think an aq2200 will do the trick of supplying this beast with the power it needs, and if not, feel free to give me an affordable suggestion.Also, do you guys think a high output alternator would be necessary for a late 90s Tahoe if I wired another battery in the trunk?Depends on your listening habits Are you going to be playing at full tilt 99% of the time? Or just for short demos?What battery were you looking at for the rear? I'd get the biggest xs power or kinetik you could afford, watch your voltage at full tilt, if it's consistently low, get a h/o alt.What is considered low voltage?Also, who makes the best (affordable) alternators? I know of Iraggi and Excessive Amperage, but that's about it. Are there any companies that are better?
March 2, 201115 yr Author I'd go with an alternator. I have a h.o and 1/0 big three done, and I'm going to be getting a second battery too.That Audioque can suck some power, and if you're like me, it's loud almost all the time.Also, you know you just doomed yourself to posting pictures of this beauty when you get it? hahaCould you give me the best link you can find for instructions on the big three? I can barely remember how you do it. Pictures/diagrams are preffered.And of course Pictures will be up the day it comes in. Amp too!
March 2, 201115 yr Author Well, I'm pretty much excited right now. Just ordered my new BTL N2 18 a few minutes ago. Just wondering if you guys think an aq2200 will do the trick of supplying this beast with the power it needs, and if not, feel free to give me an affordable suggestion.Also, do you guys think a high output alternator would be necessary for a late 90s Tahoe if I wired another battery in the trunk?Depends on your listening habits Are you going to be playing at full tilt 99% of the time? Or just for short demos?What battery were you looking at for the rear? I'd get the biggest xs power or kinetik you could afford, watch your voltage at full tilt, if it's consistently low, get a h/o alt.Could you give me a link to an acceptable battery for my conditions? There are so many, I'm not sure which one is the best for car audio...
March 2, 201115 yr 1 run an extra cable from battery negative to ground 2 run an extra cable from engine block to ground3 run an extra cable from alternator to battery positiveIt's usually very easy to find/do this, all the wires are already there, you just identify them and add a bigger wire to the factory grounds/power
March 2, 201115 yr 1 run an extra cable from battery negative to ground 2 run an extra cable from engine block to ground3 run an extra cable from alternator to battery positiveIt's usually very easy to find/do this, all the wires are already there, you just identify them and add a bigger wire to the factory grounds/powerLink to Big 3 Thread:
March 2, 201115 yr If your voltage drops to the 12s then it's relying on your batteries for the power, which means there being drained and not charged. If it's in 13s your batteries are getting some charging but should be fine.xs power batteries are great, I'd get the biggest one you can fit / afford.Also, DC Power makes excellent high output alternators Although there sometimes difficult to get a hold of, but in my opinion as pissed off as I get when I can't get a hold of them, their products are worth it.
March 2, 201115 yr stay away from DB Electric alternators! lol. Pieces of junk if you ask me. go with a reputable brand of alternator.
March 2, 201115 yr Author 1 run an extra cable from battery negative to ground 2 run an extra cable from engine block to ground3 run an extra cable from alternator to battery positiveIt's usually very easy to find/do this, all the wires are already there, you just identify them and add a bigger wire to the factory grounds/powerDo I "add an extra wire" on top of the wires that are already there, or do I completely replace them? And I should use 0 gauge, correct? There seems to be a discrepancy in step #3 on the link that was provided. Edited March 2, 201115 yr by burko
