Okay, so when you wire three subs together, there are always weird impedance numbers. It's never a solid one or two ohm. It's always some strange decimal.
Example:
So I was wondering, what if you wired, say, two dual 1's together for a 1 ohm load, then wired a dual 2 to a one ohm load and plugged them all into the amp, would the third sub be in phase or all out of wack?
I just want to know if this will work out, because then you have all three subs together on a solid 2 ohm load.
EDIT: Just to clarify, the 2 dual 1 ohms subs and the single dual 2 ohm sub are wired completely separately and then the two sets of leads are plugged into the amp for a solid 2 ohm load.
Edited by Dutchie.
Your power distribution would be uneven.
I figured as much. Just wanted to see if somehow it would work. Thank you.
What's the problem with the odd ohm load?
There isn't a problem with odd at the amp, the problem is when each sub isn't the same.
the resistance is not the same.
Use 2 subs or get a 4th one. :)
What's the PB with 1.34 Ohm ?
