Posted November 19, 200520 yr Unfortunatly I can't take any credit for the design of this box (but Decware.com can) I only take credit for 12 hours of labor building the thing.Keep in mind this is for a HT Those are a pair of a/d/s/ 3 series, sweet little drivers but I'd like to see some RLI's in there.First impressions of build: WAY harder to build than anyother box I've done so far. But seeing how this is my 5 or sixth box (ever) depending on how you count, I'm not doing too bad. Freaking rad design, I nod my head to the guys over at decware.How does it sound, well pretty good, I only had a few mins with it this morning before work. I'm not sure it is as accurate as possible but that could very well be my build or the driver/box combo. But as far as taking an advanced generic design it worked rather well. Its really loud for a pair of 8's with 7mm of xmax. I doesn't keep up with my IDmax in the T-line but its probably just as accurate. I had my max running at 8ohm so 1400watts and these 8's are wired to 4ohm so somewhere around 2500wrms. I have the sub level around 3/4 on the receiver (supposedly 4v output!) and at about 2/3 gain on the amp.More later, anyone have good ideas on finishing (veneer, marble, Etc.?)later,b
November 19, 200520 yr Nice work on the enclosure - looks good! Lots of options for finishing.Formica comes in nearly eight hundred gazillion different colors/textures/etc now. Wood, laminate, metal, stone. www.formica.com Might be an option.
November 19, 200520 yr anyone have good ideas on finishing (veneer, marble, Etc.?)later,b<{POST_SNAPBACK}>Take a pic of your living room or whatever room it is going in and then a more educated answer can be given. As far as the box goes...very nice work. Please try some other drivers, maybe even fool with the sealed portions dims by sticking a block or two in there if you can, please. Anyways, great job and I am looking forward to your in depth review, should you choose to do one.
November 30, 200520 yr that looks very well done<{POST_SNAPBACK}>sorry I didn't see this earlier. Welcome to the WO club, my friend. I just saw your post on the decware boards.here's mine w/12 RESE's in it.
