Posted March 9, 201115 yr I would like to build a ported enclosure for a single 12. I'm ok with building it but I'm not to positive on figuring port displacement and tuning and I figured someone here could probably help. I want the box to be 2 cu ft after port and sub displacement tuned to 32-33 hz, double baffle, sub and port firing at the trunk. I want to have quite a bit of trunk space with the box and amp in there. I measured what space I'd like to utilize and came up with 16-17" tall(preferably 16) x 24-26" wide x 16-17" deep, is that big enough for size box I'm wanting? For anyone curious I plan to run either an icon or a ssd off my sae 1200. I'm going to use one of my Orion xtr pros until then. Also I'm going to build this enclosure out of birch plywood. I was thinking about staining it like a dark cherry or something, open to suggestions. Any and all help is greatly appreciated.
March 10, 201115 yr check with Bromo or JblcamryOoh yeah !You will love their work ! I don't need no more/no other box designers !!!
