So i've decided to go with the 18" BTL N2, but was wondering if i should get the cooling option or just the p chamfer because in the tech area it says getting the cooling will weaken the metal- what do you guys suggest i do- im getting all other options. Its going to be for everyday play. Thanks in advance.
Edited by lonelyprince24
Cooling (cooling includes p chamfer) is for daily and not recommended for spl coil option.
Thought so- thanks for the fast reply. much appreciated.
If your going to throw a bunch of power to it daily get the cooling option. You could have a slightly stronger motor without the cooling option, but what good is it when you cook the coil due to insufficient cooling.
true true. thanks
When they say it loses a little motor strength, its meant to inform people who is number chasing who wants to get every tenth they can.
Even if used for SPL, cooling won't cause a big lost.
With that said, for daily, cooling is recommended. You won't ever be able to tell the difference either way.
But better to ask and get a forsure answer then assume because you don't exactly know.
