Posted March 17, 201115 yr So i've decided to go with the 18" BTL N2, but was wondering if i should get the cooling option or just the p chamfer because in the tech area it says getting the cooling will weaken the metal- what do you guys suggest i do- im getting all other options. Its going to be for everyday play. Thanks in advance. Edited March 17, 201115 yr by lonelyprince24
March 17, 201115 yr Cooling (cooling includes p chamfer) is for daily and not recommended for spl coil option.
March 17, 201115 yr Author Cooling (cooling includes p chamfer) is for daily and not recommended for spl coil option.Thought so- thanks for the fast reply. much appreciated.
March 18, 201114 yr If your going to throw a bunch of power to it daily get the cooling option. You could have a slightly stronger motor without the cooling option, but what good is it when you cook the coil due to insufficient cooling.
March 22, 201114 yr Author If your going to throw a bunch of power to it daily get the cooling option. You could have a slightly stronger motor without the cooling option, but what good is it when you cook the coil due to insufficient cooling.true true. thanks
March 22, 201114 yr When they say it loses a little motor strength, its meant to inform people who is number chasing who wants to get every tenth they can.Even if used for SPL, cooling won't cause a big lost.With that said, for daily, cooling is recommended. You won't ever be able to tell the difference either way.But better to ask and get a forsure answer then assume because you don't exactly know.
