November 26, 200520 yr Already doin better than Flakko ...NG<{POST_SNAPBACK}>That's EXACTLY what I was thinkin...
November 26, 200520 yr Blade got stuck huh? Flakko's on;y problem seems tobe controlling the jigsaw, or was it a combat knife he used to make that hole?
November 26, 200520 yr Blade got stuck huh? Flakko's on;y problem seems tobe controlling the jigsaw, or was it a combat knife he used to make that hole?<{POST_SNAPBACK}>You didnt see the 1/4" gap in the back filled with caulk.
November 26, 200520 yr lol I had the same thought as everyone else.hope your box comes out well. no pun intended.
November 26, 200520 yr you doing that inside your house? hows the sawdust on everything going for you?
November 27, 200520 yr Author haha i did all the cuttin out side and just putin it together inside cuz its really freakin cold i just brought the saw in cuz i didnt want my brothers to get hurt with it or something.. thanks for yalls opinions i apperciate it ill update more pics here in a lil bit i need some advice on waht tool to use for the circle and the terminal cup hole..
November 27, 200520 yr rotozip gives most exact and is easy to work with, just slowjigsaw works great just take ur time with itrouter isnt exactly my friend lol
November 27, 200520 yr Terminal cup ?only suckers use those.Rotozips suck balls.They are LOUD and cut really slow. I can cut a better circle out with a jig saw than with a roto zip.
November 27, 200520 yr i like using term cup for ease of diconnecting and swapping subs.<{POST_SNAPBACK}>Disconnect at the amp maybe?You don't use the same box for multiple subs do you?
November 27, 200520 yr i like using term cup for ease of diconnecting and swapping subs.<{POST_SNAPBACK}>Disconnect at the amp maybe?You don't use the same box for multiple subs do you?<{POST_SNAPBACK}>actully asometimes i do, just to try diff subs in diff enclosures. but the term cup is always a nice addition
November 28, 200520 yr dont get much easier than using the plain wire... unhook at either the amp or the termnal...
