Blade got stuck huh?
Flakko's on;y problem seems tobe controlling the jigsaw, or was it a combat knife he used to make that hole?
You didnt see the 1/4" gap in the back filled with caulk.
lol I had the same thought as everyone else.
hope your box comes out well. no pun intended.
  • Admin
looking good so far, more pix of the pup
haha i did all the cuttin out side and just putin it together inside cuz its really freakin cold i just brought the saw in cuz i didnt want my brothers to get hurt with it or something.. thanks for yalls opinions i apperciate it ill update more pics here in a lil bit i need some advice on waht tool to use for the circle and the terminal cup hole..
a jigsaw or router would be good for the circle/terminal cup.
rotozip gives most exact and is easy to work with, just slow
jigsaw works great just take ur time with it
router isnt exactly my friend lol
Terminal cup ?
only suckers use those.
Rotozips suck balls.
They are LOUD and cut really slow. I can cut a better circle out with a jig saw than with a roto zip.
drill a hole, put the wire through, caulk it up
i like using term cup for ease of diconnecting and swapping subs.
Disconnect at the amp maybe?
You don't use the same box for multiple subs do you?
actully asometimes i do, just to try diff subs in diff enclosures. but the term cup is always a nice addition
