Posted April 7, 201115 yr Can somone toss me a few opinions on a sub box for a fully loaded Fi Bl 15. the max height of 16, with of 35, and depth of any. i used the 12volt.com port and box calculater. i typed in a 35 width,16 height, 16 depth. if came out to be around 4 cubes.with a port lenght of about 25, port with of 3inches i dont know if that right... i wanting to make a box for a tuneing of 30 or 32hz. i also used the RE calulater.. but it dont seem right... can some one help me out. toss in your opnion? i have a 1500 watt amp,i want listen to some bassy songs, mostly rap.
April 7, 201115 yr port area is too small!!! I would run on the high side like 16 sq in per cube...I run mine @ 20 in per cube and it is a very noticeable diff in out put I even dare say 2-3 dbthat box will only have 43.5 in sq of port area you will need a MIN of 48 but more like mid 50s to mid 60s Edited April 7, 201115 yr by 144dbFiBl15
April 7, 201115 yr just off top of my head if you go 16 x 35x15 that will give you 4.8 and change cubes but after sub disp. and port it will put you round 3.8 ish cubes.....dont quote my in using my fingers and toes here.....
April 8, 201115 yr Author i dont know much. but im just needn a link or a webpage were i can try to make my own, without paying anything... its on a budget haha
