Posted November 30, 200520 yr Hi all, I am still waiting for my US Amps to arive, and in the mean time I am ordering new wire and other things I will need for my new install. I have 0 Awg comming from the Battery back to the trunk. I will be running a USA-300x, USA-400x, USA-600x and a USA-50. Should I run 4 or 8 awg wire to those amps Power and ground? Also should I run one large fuse, or get a distribution block with seperate fuses to control each individual amp? Just wondering what wire and hardware I should use to insure a strong safe system.
November 30, 200520 yr i dont have much info on the og amps listen to splblazer.but what i would do since you got 4 amps, get a 4 way distro block and 8 gauge all the amps
December 3, 200520 yr yea the old ones take 10 awg<{POST_SNAPBACK}>use 8 guage wire I AM A ls runnign similar models
December 3, 200520 yr Author yea the old ones take 10 awg<{POST_SNAPBACK}>use 8 guage wire I AM A ls runnign similar models<{POST_SNAPBACK}>Ok Thanks. The owners manual I read online said use at least 8 awg wire for the ground and power. Just wanted to check. One thing I am confused on now, is why 2 powers and 2 grounds? Do they both have to be wired up? If so that means a lot more distribution blocks then I thought lol
December 5, 200520 yr yea the old ones take 10 awg<{POST_SNAPBACK}>use 8 guage wire I AM A ls runnign similar models<{POST_SNAPBACK}>Ok Thanks. The owners manual I read online said use at least 8 awg wire for the ground and power. Just wanted to check. One thing I am confused on now, is why 2 powers and 2 grounds? Do they both have to be wired up? If so that means a lot more distribution blocks then I thought lol<{POST_SNAPBACK}>i dunno why but yeh they both have ot be wired up i think it probably helps with current flow to the amp or something like that
December 5, 200520 yr Author yea the old ones take 10 awg<{POST_SNAPBACK}>use 8 guage wire I AM A ls runnign similar models<{POST_SNAPBACK}>Ok Thanks. The owners manual I read online said use at least 8 awg wire for the ground and power. Just wanted to check. One thing I am confused on now, is why 2 powers and 2 grounds? Do they both have to be wired up? If so that means a lot more distribution blocks then I thought lol<{POST_SNAPBACK}>i dunno why but yeh they both have ot be wired up i think it probably helps with current flow to the amp or something like that<{POST_SNAPBACK}>Yeah I think so too. Since they puch large amounts of power I assume its to allow us to install 4 awg worth of wire to the amps using 2 8 awg wires. It helps keep the entire install uniform that way in my opinion. And WoooHoo got my last amp tonight! So the whole install is this.. USA-50, USA-400x, USA-600x, USA-300x! Rock ON! lol
