Posted November 30, 200520 yr I just got a US Amps USA-442 and I was wondering what kind of info can you guys give me on it, power that I should expect, how good is the amp, you know things like. Help me feel good about my purchase . Also, I understand that it has a very complicated built in crossover, can someone help me out with this also? Thanks
February 2, 200619 yr Author Found out how to use the crossover after a lot of searching. Anyway does anybody know if can run the amp at a 1 ohm load? Thanks!
February 3, 200619 yr Found out how to use the crossover after a lot of searching. Anyway does anybody know if can run the amp at a 1 ohm load? Thanks!<{POST_SNAPBACK}>just of the bat u probaly cant run it at 1 ohm i i remebr the usa series usually was 2 ohm stable dats it buh again im just guessing here
February 3, 200619 yr As a generic answer to your question (not sure if the amp is stable there), just wire two 2 ohm coils in parallel. Or 4, 4ohm coils in parallel and you will have one ohm. Here is the math:1/(amp ohm load) = 1/voice coil ohm1 + 1/voice coil ohm2 + 1/vco3+....Only use how many voice coils you have. In the case of a single sub with 2ohm DVC it would be 1/x = 1/2 + 1/2 :therefore x = 1 ohmFor 2 DVC 4ohms it would be 1/x = 1/4+1/4+1/4+1/4=> 1 ohm loadFor 1 DVC 4ohm it would be 1/x = 1/4+1/4 => 2ohm loadBUT PLEASE CHECK THE AMP SPECS BEFORE GOING TO 1 OHM!
February 4, 200619 yr The regular USA series should be 1 ohm stable in stereo, mono 2 ohm. I believe it was the Xterminator series that was 2 ohm stereo. I may be wrong though. And the HCs were .5 or .25 ohm.
August 30, 200718 yr does anyyone have a manual operation for US Apms USA-442?i really need that.thanks
