will probly be getting 2 aq hdc3 15 subs. what amp should i use with these and what else would i need.
why not get an AQ amp to match?
Well, they are rated at 1000rms a piece, so the Audioque 2200d would be perfect if you are going to stick with Audioque.
I would use a AQ2200d For 2 of them.Each is rated at 1000rms plus.
Thats what powered them before and I was able to do 146db+
You could also look in to the new Crescendo amps.
They had a pre-order, but not sure if still going on.
Aq amps are very good for the price, i bought the 1200 never had a problem with it and never comes even close to getting warm when i have it putting out
