July 18, 201114 yr Author 15k will give me plenty headroom if I want to add another 15" or two. Dan says they will handle 3,000 daily. So, I wanna have enough power to test its limits in the real world. I am working on a modular amp rack/ batter bank that I can add to and/or remove from the vehicle. So if I want I can have a "daily" set up, and add additional 15,000 watt banks for demos and shows.
July 18, 201114 yr You talk to calmly about "adding another 15 OR TWO". After all it is ONLY 15k Lets see pics!
July 18, 201114 yr Author Will be running 4 planet audio on 4 shireken batteries per bank two strapped on each coil for burping 15,000 is way more enough for 3 15's. I will only add more banks if I do any burping on multiple subs. One amp will only be used for daily listening. But I need the extra power for abuse testing
July 18, 201114 yr Sounds like fun, you should make some videos and share with us when you do this testing.
December 10, 201113 yr Any updates as to how this turned out? Numbers or Vids of this "Divine" Setup.
