Posted May 12, 201114 yr New box design for a 15" Ascendant Audio SMD going in the back of a Lexus RX300. This is for Jared Brewer, aka: rxdriver11 from the smd fourm.
May 12, 201114 yr Looks great! Those SMD subs are monsters. I like the port design, I prefer that over a standard L-Shaped.
May 12, 201114 yr Does the SMD need to be installed vertical because of its depth and weight? or if it is installed horizontally does the motor need to be supported?
May 12, 201114 yr Does the SMD need to be installed vertical because of its depth and weight? or if it is installed horizontally does the motor need to be supported?There is a threaded rod in the motor for supporting it when mounted horizontally.
May 12, 201114 yr Does the SMD need to be installed vertical because of its depth and weight? or if it is installed horizontally does the motor need to be supported?There is a threaded rod in the motor for supporting it when mounted horizontally.Thank you Duran.Nice box design and tutorial RAM_Designs.
May 12, 201114 yr Author Does the SMD need to be installed vertical because of its depth and weight? or if it is installed horizontally does the motor need to be supported?There is a threaded rod in the motor for supporting it when mounted horizontally.Indeed. I didn't include it in the design, but I gave him an idea of how to brace it in the email I sent...in case anyone was wondering why there wasn't anything back there to support it.
