The website says between .8 and 1.5 cu. ft. for a sealed enclosure. Could someone give me a more exact size? Or at least tell me what would be the difference in sound if it was placed in a .8 cu ft box vs a 1.5 cu ft box? I'm currently running an IDQv3 12 and was given an exact volume size for a sound quality setup. What do you guys suggests? I listen to rock and electronic music. Thanks in advance!
The larger you do the more low end extension you get, you also increase efficiency and decrease power handling.
It's best to go right in the middle, you should like it.
Right now I have 2 idq v3s in 1 cu ft enclosures running off 2 jl slash v2 500 watt amps. So a 1 cu ft box would sound good? I was considering selling the 2 amps and getting one 1000 watt slash v2 and running just one FiQ 12 BUT if I have less power handling in a smaller box do you think the 500 watt amp would be sufficient for a 1 cu ft box?
