May 22, 201114 yr Author You just replace alternator+ to battery+, battery- to chassis, and engine ground to chassis cables with an upgraded gauge wire basically right?
May 22, 201114 yr You just replace alternator+ to battery+, battery- to chassis, and engine ground to chassis cables with an upgraded gauge wire basically right?BIG3
May 23, 201114 yr So id be good just runnin 4 gauge in those places?You could, but I would do 1/0 through-out myself.
May 24, 201114 yr There's a ton of threads on wiring. Just search. Try looking into welding wire. weldingsupply.com or call a local welding supply shop. Its pure copper so you should treat the exposed ends there was a thread about this like 2 days ago
