Posted May 23, 201114 yr It took a little longer then expected, but my brother and I finished his truck stereo. The center console came out great!!!! My brother did almost all of the fab work, as I was busy with school and couldn't help much. We decided to go with a sealed enclosure for the death row at about 1.5 cu ft. It sounds fantastic in his truck. I wouldn't hesitate to run them in sealed boxes. His front stage consists of aura sound buyouts and vifa tweets with the madisound XO for them. Here are some pics of the build. Took a couple weeks to do everything. The box itself is in 3 parts. The enclosure for the sub, then the separate piece with cup holders, and the top piece that houses the enclosure from the stock center console. The subwoofer just fit perfect for the width requirement between the two front seats.The XO for front speakersModified the stock tweeter mount to fit the new tweeter. The rockford amp is under the rear seat where stock jack wasgood finished pic
May 23, 201114 yr Looks Great!!! Custom center sub console!! You must be a 2 handed drinker with all those cup holders!!
May 23, 201114 yr Author Thanks for compliments. Basically just took it piece by piece. Had to re-cut alot as the sides for box enclosure are slanted inwards at angles, and the top piece from old center consol is framed in so it all looks flush. Again, I didn't do too much of the fab work, my brother did. It was just all my older equipment given to him and he made it all work. Will never be able to go back to stock however as we did butcher his stock center consol to get the cup holders and such out of it. As well as hack off all the metal brackets for his top lid. It sits quite a bit higher then the stock consol did, but is way more comforatable height I think now.
