Posted May 24, 201115 yr Subs: 2 dual 2 12" sa'sAmp: kicker 2500.1Car: 01 monte carloCurrently I have a 3.5cu box with a slot port, both fired towards the rear. They were fired into the cabin and I got a 140.x. I was told firing them the other way (how they are now) would post better numbers. I've yet to get metered though and can't tell a difference by ear.The plan is to build a new box with a 6" aero port firing to the right with subs facing back. Can anyone chime in with a better suggestion or confirm this would post good numbers?-Thanks
May 24, 201115 yr Port back sub back is going to be your best setup, unless you fire forward and seal the box and subs from the trunk.
