Okay, so my problem is that my brothers HU only has one RCA output that is currently running to the amp he had on his subs, well now we are hooking up another 4-channel amp for his 4 6.5's he has in his car now. So i need another 2 RCA outputs somewhere to go to the 4-channel amp.
*Can I just get 2 RCA line output converter's and tap one into one of the 6.5's in the rear and one of the 6.5's in the front?? He doesnt want to upgrade his HU right now.
Any input is always appreciated. Thanks :fing34:
4 channel has no pre amps? It should say "Output" or "Pass thru" or something like that. The two rca jacks u didn't use.
EDIT: I'll make that more clear. Just run a short rca from the 4-channel amp's pre outs to the other amp's input and you should be good. Any decent 4 channel should have a pre amp output.
Edited by An-i-no
Im a little confused by your post...'pre-amps'?? My problem isnt connecting the RCA's to the amp its connecting them to the HU to get a signal because there is only one RCA jack on the HU and i need 3. (2 for the 4-channel and the other for the sub amp)
OHHHH....so i can just run an RCA from the one amp to the other? thats soooo much easier that way..lol. thats what you mean right?
Thanks for the clarification...lol
Yes, but ONLY if it's the pre out/output/pass thru section. NOT the inputs lol.
Edited by An-i-no
For sure...lol. Thanks again :fing34:
