Posted May 29, 201115 yr my question is, should there be any nocitable difference if i switch boxes.it will be for 2 10" chaos on a t1500-1bdmy current box is a 1.8 cubic feet tuned to 32hzand will build a bigger box, a 2.5 cubic feet tuned to 33hzall this measurements are net volume, and the bigger box has a bigger portthanks
May 31, 201115 yr There will be a noticeable difference in output, assuming that you're not able to push the subs as far as you want to with your current box(since it seems to be pretty small). Edited May 31, 201115 yr by RAM_Designs
