my question is, should there be any nocitable difference if i switch boxes.
it will be for 2 10" chaos on a t1500-1bd
my current box is a 1.8 cubic feet tuned to 32hz
and will build a bigger box, a 2.5 cubic feet tuned to 33hz
all this measurements are net volume, and the bigger box has a bigger port
thanks
There will be a noticeable difference in output, assuming that you're not able to push the subs as far as you want to with your current box(since it seems to be pretty small).
Edited by RAM_Designs
