Posted May 31, 201114 yr hey wud up? i'm running two Sundown amps( 100.4 and saz1000d) . i want 1 battery to run the system n my Dodge Ram....... what model should i get?
May 31, 201114 yr Are you looking to replace your starting battery in the factory under hood location or add one elsewhere?
May 31, 201114 yr Author replace the starting battery unda THE hood...... Edited May 31, 201114 yr by Firk-eze1
May 31, 201114 yr I'm pretty sure most of those 1/2 ton dodge ram pickups use the group 65 in the last 10 years. If so, the D6500 would be your best bet. You might be able to fit a D3100 even.
