Posted June 2, 201115 yr can a HO alt still work but get damaged and charge at a lower voltage, around 13.8V when it used to charge around 14.8V?
June 2, 201115 yr Author it has seemed to charge lower for quite a while, so its like it just keeps on working but not as good as it did. If a diode or a coil could bust, but other coils/diodes or something still remain, so it still works but not as good, that would suck. But if a broken part means it will completely die, good, id rather repair it and get full output again.
June 3, 201115 yr Author Hmmmmm don't I know you? lolSN looks familiar... face in avatar looks familiar...wudup man!
June 3, 201115 yr Hmmmmm don't I know you? lolSN looks familiar... face in avatar looks familiar...wudup man!Nothing much. I registered over here about a week ago. Not a bad forum. So have you had any of this stuff tested yet?
June 8, 201115 yr Author I got lucky this time, after a couple days everything is back to normal. No more pissing about... gonna install the 2nd alt before I do the new recones for the 1803s
