Posted June 11, 201114 yr HiI want to get 2 12" XCON G2s when I come back from my trip.Vehicle Make and Model: 2008 BMW 328i SedanDirect of Box/Subs: Subs facing the same way as the portSealed or Ported: PortedNumber of Subs: 2Brand and Model of Subs: SSA XCON 12Max Dimensions: (Not sure yet here, Idk the cubic feet of my trunk, but even after the box I would love to have at least 15% available, but it may vary I understand)Port Color: BlackFlush Mount Ring Color (if flush mount is chosen): What exactly is this? (native spanish speaker here)Carpet Color: Dark Gray (Like the one in the DCON enclosure picture on the argent website)Zip Code for Shipping Quote: 33160Now Idk if its better to have the port in between the two subs or on a side. Also, idk how big the box should be. I dont want to completely take the whole trunk space, but I understand 2 12s will require a decently big enclosure for optimal performance.Lastly, do you recommend double baffle for 2 12s? (amp is sundown 2000d for now, will be a 3500d in the future)Whats exactly is Wooden Dowel Bracing? And do you guys use 45 angled corners? What about ports with curved end (like the dcon enclosure)Thanks
June 13, 201114 yr I think you would be best with about 4.5 cubes for the pair of them. I would recommend double baffle and flush mount since the Xcons are pretty beastly 12's. A box like this would run $198.00, that includes the 10% off this month. Andrew
