Posted June 14, 201115 yr This is my first box so I have no idea what I'm doing!7.573 cubes @ 34.21HzI may reduce the port width from 8 inches to 6 inches which will bring the box to 8.574 cubes @ 28.54Hz. Input?(Will change a little with sub displacement)Bottom: 48" x 22"Top: 48" x 22"Left Side: 21.25" x 20.5"Right Side: 20.5" x 20.5"Back: 48" x 20.5"Front: 41.25" x 20.5"Port L1: 14.5" x 20.5"Port L2: 13.25" x 20.5"What would sound the best? Any suggestions?
June 14, 201115 yr I haven't doudle checked your math, but the indicated volume and tuning will be fine. Sub will be pretty efficient in a box that size, too...
June 14, 201115 yr Author I haven't doudle checked your math, but the indicated volume and tuning will be fine. Sub will be pretty efficient in a box that size, too...Thanks for the input! I just wasn't sure if there was a rule of thumb as to how long you should try to make the port walls in a L shaped box.
