Posted June 20, 201115 yr hey guys does anybody know how you would wire this qvc beast? I know you would take a pair of the voice coils and wire them to an amp. So im guessing you would do the same to the other side. Heres my question, when wiring separate sides of the speaker to its amp would you wire as you normaly do or is there a special way? IM goin to put one amp per pair of coils, i just want to make sure i get 1ohm power from each. so would i just wire each side to 1ohm or is there a special way with a qvc sub?
