Posted June 21, 201115 yr Well I have decided to get 2 12"Dcons and am gonna run them in about 3 and a 1/2 cubes at 31 hz. I am considering the following amps. What would your choice be?( a little head room is ok}1. Arc Audio KS300.2 700x1@4ohms $350.002. Kicker zx750,1 750x1@2ohms $250.003. Audioque AQ750.1 750x1@1ohm $200.004. Sundown SAZ1000 1000x1@1ohm $260.00 refurbished5. Hifonics Brz1200 900x1@2ohms $175.006. US Amps VLX 1DE 1000x1@1ohm $200.00
June 21, 201115 yr That Sundown saz1000 would be the best, Sundown has great customer service I have noticed and products that do not dissapoint.
June 21, 201115 yr I think I would choose the Sundown, it's a high quality product that will give you plenty of headroom @1ohm or match up well with the Dcon rms @2ohm. It will provide the most power out of the amplifiers listed, it is strappable, and if something ever happens to it, you know where to get it fixed.
June 21, 201115 yr I vote sundown as well. They really make a quality product. All the advantages Ohjay listed makes it an easy decision in my mind.
June 21, 201115 yr Sundown FTW !But the brz is cheap, and you don't need more than that.All of them are good, so it's up to you.What is your budget ?Get the cheapest and keep some money for ...some sound deadener or anything you will need for your build : wire, rca, fuse, fuse holder,...etc
June 21, 201115 yr the Audioque is also a great amp, i run a aq2200 and it has never even gottin slightly warm. Sundown would be the best but is a little more expensive, just depends on how much more your willing to spend and what company you want to have run your setup.
June 21, 201115 yr The AQ is also strappable and would be my second choice. If you're on a tight budget, it would do you well.
