could someone please double check these numbers. I know this box is small but that is all i have to work with and its still at the minimum.
I assume that you are using a (L) port? Since you port lenght is 15" and the box stats says 12"? unless you front is 3" thick?
Edited by jj1479
If the height of your enclosure is 17" then it would be difficult to have a port height of 17" ? I would like to see it have a little more port area per foot. Why 3 xtra baffles?
What subs are going in this?
Aeroports will help if that's all the space you have to work with.
port height should be 15.5"
i see now that you and sefugi pointed it out. thank you. and im using 3 baffles for double baffle and flush mount.
Are you going to re-figuire the port area now that the height is smaller? :drink40: on the 3 baffles!!
When i chane the port height to 15.5 it changes the posrt tuning to 32.59 which i would rather have than 34.
Yes, but if you look you also lost port area which I would rather not have.
x2 I would try to get it up to at least 12 inches per foot.
Edited by Ohjay
