Posted June 24, 201115 yr well what kind do you guys use? im about to mount my woofers but i dont feel comfrontable using the ones i bought to mount my fuse holders down, what use what kinda of should i be looking for i live in southern wisconsin so i have a menards thats about it and a home depot, but that like a 20min drive not really wanted to go all the way there for it unless i really have too
June 24, 201115 yr normal drywall screws work for most applications, if you want to get fancy you can use bolts and T-Nuts.
June 24, 201115 yr Author how long you think ? and it doesnt need to be any screw with an aggresive looking thread,k,m
June 24, 201115 yr my box is almost 2 inches thick.. my NS1's would SNAP heat tempered wood screws.... i started useing grey deck wood screws.. non tempered.. heat tempered tents to SNAP by design but the non tempered stretchs ... dry wall screws are too fine of a thread IMO the MDF will just be dust between rounds on the screw,. i would only use dry wall on mid bass and my tweeters and cuch.. but thats me
June 24, 201115 yr Author http://www.menards.com/main/p-1638934-c-8940.htmthinking maybe these?so you think these will do? its pretty much the last peice of work on my build to finish it
June 24, 201115 yr http://www.menards.com/main/p-1638934-c-8940.htmthinking maybe these?so you think these will do? its pretty much the last peice of work on my build to finish itthose are what i used on my NS18 i didnt run it long but they worked.. nice big head grab the basket well
