Vehicle Make and Model: 05 Acura TL
Direct of Box/Subs: Facing Cabin
Sealed or Ported: Ported
Number of Subs: 1
Brand and Model of Subs: SSA XCON 12
Max Dimensions: Dont know but I dont mind using trunk space
Port Color: Black
Flush Mount Ring Color (if flush mount is chosen): Black
Carpet Color: Black
Zip Code for Shipping Quote: 21093
Double Baffle
Wooden Dowel Bracing
Please let me know ASAP !
He needs to know your max dimensions or he could make a box that doesn't fit someway and that would be on you.
Go out to your car with a tape measure measure the Width (side to side) Depth (Front to back) Height (bottom to top). Until then, I don't think he can help you.
According to Acura cargo 12.5 cu ft
Ok this is the max Height from the (opening) of the trunk 18
H (Inside the trunk) 17
W 36.5
D 28
Those are the max for the enclosure leaving alil space in the front , back and sides . Gonna cover 96% of the trunk I'd say
Internal Volume: 2.65 ft^3
Port Area: 37.70 in^2
Enclosure Tuning: 30 Hz
Here is what I came up with:
17 deep
15.75 tall
32.25 wide
double baffle
flush mount
2.5@ 31HZ
Andrew
17 deep
15.75 tall
32.25 wide
double baffle
flush mount
2.5@ 31HZ
Andrew
Sounds good ! Let me know ASAP . PM or email me @[email protected]
  • 2 weeks later...
