Posted June 28, 201115 yr Still need to seal the wall off but a lil vid for you guys Lemme know wat you think??
June 28, 201115 yr Vid looks great!!! Is this the wall you were making modifications on? What are your thoughts on the changes?
June 28, 201115 yr Author Vid looks great!!! Is this the wall you were making modifications on? What are your thoughts on the changes?Yup thats the wall, only mods were:45's on all corners of the boxMuch bigger port areaThose 2 simple change made the world of difference!! I went from 147.xxDB @ 38hz to 149.9DB @ 32hz, my 25hz score has gone up a whopping 5 DB!!! And those scores are with the wall unselaed, will try to seal it this week and re test, as I also got my O scope so I can turn the amps up a bit more now
June 28, 201115 yr Vid looks great!!! Is this the wall you were making modifications on? What are your thoughts on the changes?Yup thats the wall, only mods were:45's on all corners of the boxMuch bigger port areaThose 2 simple change made the world of difference!! I went from 147.xxDB @ 38hz to 149.9DB @ 32hz, my 25hz score has gone up a whopping 5 DB!!! And those scores are with the wall unselaed, will try to seal it this week and re test, as I also got my O scope so I can turn the amps up a bit more now Great to hear your hard work has paid off!!
June 28, 201115 yr Author Ya man amazing how big a difference it made to the >30hz region!! I am planning a new wall already , but before I go taking anything out I wanna seal it off and shove some proper power on them Mayhems before I change my subs I would love to play 150 on music!! and a burp of 155 would be lovely too
