December 23, 200520 yr i just got off the phone with JR, he said that it can be dropped to .5 ohms, just be gentle on the volume knob in turning it up and down. let the impedance rise kick in first.also as for the wattage he doesnt know how much it will do at half ohm...the amp was built to pefrom optimally for a 1 ohm load. you can drop it no problem, but the amp will be less stable.
December 23, 200520 yr i just got off the phone with JR, he said that it can be dropped to .5 ohms, just be gentle on the volume knob in turning it up and down. let the impedance rise kick in first.also as for the wattage he doesnt know how much it will do at half ohm...the amp was built to pefrom optimally for a 1 ohm load. you can drop it no problem, but the amp will be less stable.<{POST_SNAPBACK}>whats the rms at @2ohms?
December 23, 200520 yr booklet says 800w... but it also says 1800@1 ohm. im guessing 800-1kw.but you can drop it to .5 ohms and it will still put out 2kw of power.
December 24, 200520 yr Author is it around 2k or will it put out way more then that (3k) ? Any way you could find out flakko?
December 24, 200520 yr NOO.... dont push it that much lol 2kw would be the safe point at .01 distortion. i quote "at .05 distorion it does way over 2kw" so i guess its up to you.
