Posted July 6, 201114 yr Got some of the recone glue for a 12" QGot the 60oz (have some other subs to do too)My question is, what is the mix ratio?I'd assume that its 2:1 (Black:clear)Just don't want to mess it up.Any help would be great.Thanks in advance. Edited July 6, 201114 yr by SeductiveSounds
July 6, 201114 yr 60oz damn how much did that cost?I did not use the same type. Mine was just ca glue and you spray activator on it before you clamp the parts on to it.You must be using epoxy. I thought it was 50/50 but like I said I have never used that kind. Someone with more experience then me will answer.
July 6, 201114 yr Author oops my bad, 24Ozcost me $60the one straight from Fi, got it with the recone kitya its an epoxy Edited July 6, 201114 yr by SeductiveSounds
July 6, 201114 yr No dude that is not an epoxy, if you mix it you are going to have a fire and burn yourself.It is CA glue.The black stuff is the glue, the clear is the activator.You put the glue on, hold the object down and lightly spray it with the activator...there is no 'ratio'. We sell things like this and recone kits with the assumption that people understand how to use them..
July 7, 201114 yr Author i got some direction from some local spl guys.i'm new to reconing and everyone seems to do something different when they recone.but thanks for the words of encouragement.
