Posted July 15, 201114 yr So did it? tell what you have for electrical as wellI have a DB electrical 250a alt, big three XS power d3100, SAZ-3500dBasically, my question is according to your experiences, will multiple runs help me? Edited July 15, 201114 yr by ilikedirt
July 15, 201114 yr why don't you layout your setup so we can see what you have then tell us how you are going to use your setup primarily so your question can be answered easier.
July 15, 201114 yr why don't you layout your setup so we can see what you have then tell us how you are going to use your setup primarily so your question can be answered easier.Agreed. I have multiple runs of 1/0 and it dropped my voltage to 9.4volts wtf. Then I switched and ran a single run of 8 gauge and bam 16.5 volt.
July 15, 201114 yr if your goal is to have the same voltage in the back as up front when HOT, then run a single 1/0 cable from Ground post on battery up front OR alternator ground bolt on case to ground post on battery in the rear.KEEP your amp grounded to the battery in the back AND keep your rear battery grounded to the frame\chassis as well.If you do not have rear battery, u need one for this to work.Typically, in daily drivers, i see 0.3-0.9v drop from front to rear once HOT.
July 15, 201114 yr why don't you layout your setup so we can see what you have then tell us how you are going to use your setup primarily so your question can be answered easier.Agreed. I have multiple runs of 1/0 and it dropped my voltage to 9.4volts wtf. Then I switched and ran a single run of 8 gauge and bam 16.5 volt.Wtf. There has to be something wrong then... (or is this a joke ? because it seems like it)
July 15, 201114 yr Author if your goal is to have the same voltage in the back as up front when HOT, then run a single 1/0 cable from Ground post on battery up front OR alternator ground bolt on case to ground post on battery in the rear.KEEP your amp grounded to the battery in the back AND keep your rear battery grounded to the frame\chassis as well.If you do not have rear battery, u need one for this to work.Typically, in daily drivers, i see 0.3-0.9v drop from front to rear once HOT.The d3100 will be in the back....So the saying "keep the ground wire short as possible" does not apply if running from ground post on #1 battery to ground post on battery #2?
July 16, 201114 yr if your goal is to have the same voltage in the back as up front when HOT, then run a single 1/0 cable from Ground post on battery up front OR alternator ground bolt on case to ground post on battery in the rear.KEEP your amp grounded to the battery in the back AND keep your rear battery grounded to the frame\chassis as well.If you do not have rear battery, u need one for this to work.Typically, in daily drivers, i see 0.3-0.9v drop from front to rear once HOT.The d3100 will be in the back....So the saying "keep the ground wire short as possible" does not apply if running from ground post on #1 battery to ground post on battery #2?That saying is a rule of thumb that assumes the vehicle chassis has less resistance than the wire you are using as the ground wire. This isn't always the case.
July 16, 201114 yr why don't you layout your setup so we can see what you have then tell us how you are going to use your setup primarily so your question can be answered easier.Agreed. I have multiple runs of 1/0 and it dropped my voltage to 9.4volts wtf. Then I switched and ran a single run of 8 gauge and bam 16.5 volt.Wtf. There has to be something wrong then... (or is this a joke ? because it seems like it) Running 16.5 volts on 8 gauge? I think its a joke ... XD
July 16, 201114 yr why don't you layout your setup so we can see what you have then tell us how you are going to use your setup primarily so your question can be answered easier.Agreed. I have multiple runs of 1/0 and it dropped my voltage to 9.4volts wtf. Then I switched and ran a single run of 8 gauge and bam 16.5 volt.Wtf. There has to be something wrong then... (or is this a joke ? because it seems like it) Running 16.5 volts on 8 gauge? I think its a joke ... XDyou can run millions of volts thru 8 guage (no joke )It's amps that heat up the wire. Edited July 16, 201114 yr by kirill007
July 16, 201114 yr why don't you layout your setup so we can see what you have then tell us how you are going to use your setup primarily so your question can be answered easier.Agreed. I have multiple runs of 1/0 and it dropped my voltage to 9.4volts wtf. Then I switched and ran a single run of 8 gauge and bam 16.5 volt.Wtf. There has to be something wrong then... (or is this a joke ? because it seems like it) Running 16.5 volts on 8 gauge? I think its a joke ... XDyou can run millions of volts thru 8 guage (no joke )Damm really! i didnt know that. Hehe i learned some new today
July 17, 201114 yr ^ house wiring is only 10 gauge or so (solid wire) but that runs at 120 volts @ 20 amps. or if you think of a florescent light those use about ~700 volts (think its around this area) or more to get the bulb to light up and its off of even thinner wire.
July 17, 201114 yr why don't you layout your setup so we can see what you have then tell us how you are going to use your setup primarily so your question can be answered easier.Agreed. I have multiple runs of 1/0 and it dropped my voltage to 9.4volts wtf. Then I switched and ran a single run of 8 gauge and bam 16.5 volt.Wtf. There has to be something wrong then... (or is this a joke ? because it seems like it) Running 16.5 volts on 8 gauge? I think its a joke ... XDyou can run millions of volts thru 8 guage (no joke )Damm really! i didnt know that. Hehe i learned some new today Volts yes. That doesn't mean you can run a high powered system with 8 awg
July 21, 201114 yr spark plug wires carry 40K plus volts and look how thin those wires are. its amperage that makes u need large wire not volts. but shizzon your post kind of confuses me since it seems like it contradicts its self. It seems like your saying run 1/0 ground from alt or front battery to rear battery AND ground rear battery to frame/chassis. Is this something like how you leave the factory grounds when you do big 3 since current is going to travel through path of least resistance?
August 4, 201114 yr Author if your goal is to have the same voltage in the back as up front when HOT, then run a single 1/0 cable from Ground post on battery up front OR alternator ground bolt on case to ground post on battery in the rear.KEEP your amp grounded to the battery in the back AND keep your rear battery grounded to the frame\chassis as well.If you do not have rear battery, u need one for this to work.Typically, in daily drivers, i see 0.3-0.9v drop from front to rear once HOT.This worked EXCELLENT. i have very little drop at all with the 3500d!
August 4, 201114 yr will i get ground loop if i ground bat together with a long run from the front and again at the rear? My ground in the rear isnt very good.thanks
August 4, 201114 yr technically they are already grounded together so i wouldnt see how you would get ground loop. Doing this only greatly helps sustain voltage in the rear.
August 4, 201114 yr technically they are already grounded together so i wouldnt see how you would get ground loop. Doing this only greatly helps sustain voltage in the rear.sweet thanks then I will try it.
