Posted July 18, 201115 yr So I finally got my commuter... an 04 Volvo V40. Being a sport wagon yields a decent amount of space in the rear. Taking some preliminary dimensions give me maximum external box dimensions of 35 wide x 28 deep x 18 tall, (height being semi negotiable). This gives me a internal box volume of 8.47 cu ft before speaker displacement and port volume. My goal is two 15s in a ported enclosure tuned to 30 to 32 hz. First I need to know whether any of the Fi subs would work in this size enclosure. At this point I am leaning towards the Q's but would have no problem springing for the BTL w/ high xmax option. (I would choose amps by what subs I get. AQ3500 running two Q's at 1 ohm or two AQ2500, each running a BTL at 1 ohm.)I listen to hip hop, pop, old school rap and country. I am looking for SQ but want it to go LOUD when I want. Can't allow my son to have a louder system than me. So which subs should I go with? Will two 15's work or am I stuck going with two 12s or an 18? My Ram has four 10's and I am really wanting to go larger. In truth it is just braggin rights as my four 10's have plenty of bass but hey... we all do this for fun.Thanks.
July 18, 201115 yr Four Q 15's Sealed two fired up, two fired backjust an idea, would give you a ton of cone area Edited July 18, 201115 yr by trod2902
July 18, 201115 yr Author i wouldnt think i would have enough air space for that. besides if i went sealed i would lean towards two 18's
July 18, 201115 yr 15's (about 700 sq in of cone area) only need 2-2.6 cubes a piece sealed, 2.8- 4 portedSub displacement would be about .8 cubes, so an internal volume of 8.8 would be fine for sealedthe 18's are 4-8 cubes sealed (about 500 sq in of cone area)depending on port displacement two 15's ported might do the trick
July 18, 201115 yr Author as a side note, I admittedly love the flat response of sealed enclosures. (the four 10s are sealed) I just wanted the added output of a ported enclosure. What would be louder? two 15's in ported enclosure tuned at 32hz or two 18's in a sealed enclosure?
July 18, 201115 yr as a side note, I admittedly love the flat response of sealed enclosures. (the four 10s are sealed) I just wanted the added output of a ported enclosure. What would be louder? two 15's in ported enclosure tuned at 32hz or two 18's in a sealed enclosure?i honestly cant answer that, but it really depends on your ported enclosure.hopefully someone with more info can chime in Edited July 18, 201115 yr by trod2902
