Posted July 21, 201115 yr What type of amp should i get to run two skar audio vvx 12" dual 2ohm vc.I'm thinking two Hifonics hf 2000d's one on each sub.My limit it $500 for a good quality amp that does either 3000+ watts at 1ohm or .5ohm.I want .5ohms stable Edited July 21, 201115 yr by backyardbass97
July 21, 201115 yr Why do you need that much power for a pair of subwoofers that are rated at 600wrms each?
July 21, 201115 yr Why do you need that much power for a pair of subwoofers that are rated at 600wrms each?^^What he asked!!! And why .5 ohm stable??
July 21, 201115 yr Author because there not the most efficient subs and there going in a small spl box so they perform better with more power
July 21, 201115 yr i just went thought this for my sa-12's i wanted 1,000 to each sub though figured it would be more then enough !!through alot of reading my end choices werecheap- ap15001d or ap18001d crescendo bc2000dand db-r.com's saz-1500d
July 21, 201115 yr Author well this is for an spl set up so if i blow them then ill do a recone so why dont yall give me some suggestions on some amps
July 21, 201115 yr well this is for an spl set up so if i blow them then ill do a recone so why dont yall give me some suggestions on some ampsHere you go!!
July 21, 201115 yr Are you competing? If not I don't see any reason to run so much power to those subs....especially at .5ohms. If this is for daily you should reconsider.
July 21, 201115 yr Author well its my brother system and he wants an spl ground pounder and yea were planing on competing
